ksaheta
Oct 04, 2020Aspirant
RBR50 Orbi Wifi Wifi Channel selection dropping upload
We installed Netgear ORBI RBR50 Wifi Mesh system (1 base, 1 satellite) in our home a few months ago. We have a 1Gigabit/second Google Fiber Internet connection. Most apps (movies, streaming, ...
ksaheta
Oct 06, 2020Aspirant
Thanks!
I have confimed no ports are blocked.
How do I minimize or avoid channel interference ?
Thanks
Oct 06, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
