ksaheta
Oct 04, 2020Aspirant
RBR50 Orbi Wifi Wifi Channel selection dropping upload
We installed Netgear ORBI RBR50 Wifi Mesh system (1 base, 1 satellite) in our home a few months ago. We have a 1Gigabit/second Google Fiber Internet connection. Most apps (movies, streaming, ...
ksaheta
Oct 07, 2020Aspirant
Thanks!
I have confimed no ports are blocked.
How do I minimize or avoid channel interference ?
Thanks
Mstrbig
Oct 07, 2020Master
ksaheta wrote:Thanks!
Thanks
You can run a program like NetSpot to check what channels neighbors are on and choose a different channel. 2.4Ghz is important as it will get the most interference. I found my channel 1 was less used, so I switched to it. 5Ghz has less coverage area, so you can choose pretty much any channel. I chose 48.
Also check these settings for optimum performance:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
