Dean_NZ
May 01, 2023Aspirant
RBR50 Orbi Wireless Stopped working but LAN connected devices are fine
All of a sudden, devices connected to my Wireless LAN are not able to connect through to the internet however LAN Connected devices are fine. I've tried a reboot, changing the security on my SSID bu...
- May 01, 2023
Latest FW is here: https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/New-RBR50-RBS50-Firmware-Version-2-7-5-4/td-p/2296598/jump-to/first-unread-message
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ️What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-SystemOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
May 01, 2023Guru - Experienced User
Dean_NZ
May 02, 2023Aspirant
Thanks Furrye38,
I upgraded the router firmware and reset (erase option) the router back to factory defaults but it still remembered all the settings. Power cycled everything once that was done and reran the setup but not from the orbi mobile app. Didn't work right away but eventually (20 mins or so) things were all connected back up including my Sonos speakers which had a spaz. I recommend having a PC connected and using a browser.
Tip don't forget to store all your ISP settings before you reset 🙂
Thanks again.
