ziggyray
Jul 03, 2019Aspirant
rbr50 orbi
what should someone expect for speeds if you have 280ish coming into orbi what should be avearge out speed for wireless and for wired? the speed test thru netgear or the router is consistantly higher...
Jul 03, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What OS is loaded on the Mac?
What wireless device are you using?
How many RBS are deployed?
Test with the RBS turned OFF.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Fl1ntstoneJul 03, 2019Apprentice
Hi,
As far as wireless goes it will depend whether the wireless client is connecting on 2.4Ghz or 5Ghz and what WiFi protocols you are using 802.11n or 802.11ac? 5Ghz with 802.11ac would give you the best throughput.
CheerZ
- ziggyrayJul 04, 2019Aspirant
Hello it is on 5g mostly but I have been everywhere in this router and cant see how to check or change the 802.11ac
