DirkO
Mar 01, 2019Apprentice
RBR50 password recovery failure
HI All,
So when logging in to my base station I was prompted to change my password because of security.
So I used a password manager and gave it a strong 20 character including 3 numbers and ...
Lori_H
Jun 13, 2019Aspirant
Ugh - I'm having the same issue you described. And when the password flashes up on the screen for a second I'm positive it is the password I've been trying to login with :( I really don't want to have to reset everything. :( boo.
- feignitAug 16, 2019Star
I too have this issue, I now am forced to log into my routers via Safari because Chrome just keeps asking me to reset my password after the password field flashes by for a fraction of a second.
- Retired_MemberAug 16, 2019
feignit wrote:I too have this issue, I now am forced to log into my routers via Safari because Chrome just keeps asking me to reset my password after the password field flashes by for a fraction of a second.
are you and the poster before you using the orbilogin.com or 192.168.1.1 ?
Both. No difference.
