DirkO
Mar 01, 2019Apprentice
RBR50 password recovery failure
HI All,
So when logging in to my base station I was prompted to change my password because of security.
So I used a password manager and gave it a strong 20 character including 3 numbers and ...
Aug 16, 2019Guru - Experienced User
Be sure to clear out all browser caches and saved PWs with in Chrome. Then exit Chrome then re-lauch and see if the log in page comes up correctly for you. Seems like a Chrome issue if Safari works.
Retired_Member
Aug 16, 2019
FURRYe38 wrote:Be sure to clear out all browser caches and saved PWs with in Chrome. Then exit Chrome then re-lauch and see if the log in page comes up correctly for you. Seems like a Chrome issue if Safari works.
Isn't Safari a moble app browser?
- FURRYe38Aug 16, 2019Guru - Experienced User
Both. FF and Opera have both as well.
- Retired_MemberAug 16, 2019
never heard whether the user is trying to login using a PC or mobile device
- michaelkenwardAug 16, 2019Guru - Experienced User
When it comes to password recovery, many of Netgear's manuals specifically state:
"This recovery process is supported in Internet Explorer, Firefox, and Chrome browsers, but not in the Safari browser."
The reason I asked is because of i've heard of others trying to login to their Orbi router using a Iphone app and were told to use a PC.
This might help....https://support.google.com/chrome/answer/95606?co=GENIE.Platform%3DDesktop&hl=en
- feignitAug 16, 2019Star
Here's a video of what happens
feignit wrote:Here's a video of what happens
Thanks
The 401 error makes me ask....have you ever been able to login before now? Any changes to your network, modem?
