DirkO
Mar 01, 2019Apprentice
RBR50 password recovery failure
HI All,
So when logging in to my base station I was prompted to change my password because of security.
So I used a password manager and gave it a strong 20 character including 3 numbers and ...
Aug 16, 2019Guru - Experienced User
And have you powered OFF The RBR for 30 seconds then back on after clearing all caches in Chrome to see if this helps any? Seems like a Chrome issue. Possible un-install Chrome and re-install it.
What Chrome updated recently? I presume it had been working up to some point?
feignit wrote:Here's a video of what happens
feignit
Aug 16, 2019Star
I have not powered off the orbi, but I have cleared out my chrome cookies and caches, disabled password autofill, my password manager (1password) and this still happens. All of this began when I entered the password wrong one too many times in Chrome, by the time I had figured out the correct password, I ran into this, I even went through the password reset procedure earlier today. Logging in via Safari or the app is fine.
- Retired_MemberAug 16, 2019
feignit wrote:I have not powered off the orbi, but I have cleared out my chrome cookies and caches, disabled password autofill, my password manager (1password) and this still happens. All of this began when I entered the password wrong one too many times in Chrome, by the time I had figured out the correct password, I ran into this, I even went through the password reset procedure earlier today. Logging in via Safari or the app is fine.
As suggested, it appears you're having a problem with Chrome. That fact that you entered the wrong password too many times may have caused Chrome to lock the Orbi login down. Either reinstall Chrome or take a look at the Chrome password manager. Good luck.
- SherriebassOct 01, 2019Aspirant
This is happening on my RBR20, using safari
- michaelkenwardOct 01, 2019Guru - Experienced User
You have tried the suggestions in the message before yours?
Safari does not support password recovery. See your manual.
