wallywizard
Apr 06, 2020Aspirant
RBR50: Playstation gaming on wifi EXTREMELY BAD
Problem: Playstation is lagging very bad, can hardly play. Orbi RBR50 (firmware v2.5.1.8) channel 2.4Ghz (I tried different channels, 1,6,11 etc..) back haul is on 5Ghz Residence is a two story...
Apr 07, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Turn OFF the RBS and connect the console to the RBR via wireless, does gaming still exhibit this when connected to the RBR?
Ethernet wire connected game consoles is preferred.
Please try a factory reset and setup from scratch with the RBR and RBS.
wallywizard
Apr 10, 2020Aspirant
- For my 2.4ghz I've tried channels 1,6,11
- ive rebooted/factory reset (brand new orbi)
- yes many neighbors (condo)
- PlayStation is wired into satellite. Router is on different floor.
- cable modem is 8yrs old Cisco .. I don't know the exact model.
- FURRYe38Apr 12, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Turn down the power on the RBR from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Gaming consoles have best performance if directly wired to the RBR.
Please find model# of ISP Modem.
wallywizard wrote:- For my 2.4ghz I've tried channels 1,6,11
