wallywizard
Apr 06, 2020Aspirant
RBR50: Playstation gaming on wifi EXTREMELY BAD
Problem: Playstation is lagging very bad, can hardly play. Orbi RBR50 (firmware v2.5.1.8) channel 2.4Ghz (I tried different channels, 1,6,11 etc..) back haul is on 5Ghz Residence is a two story...
wallywizard
Apr 10, 2020Aspirant
- For my 2.4ghz I've tried channels 1,6,11
- ive rebooted/factory reset (brand new orbi)
- yes many neighbors (condo)
- PlayStation is wired into satellite. Router is on different floor.
- cable modem is 8yrs old Cisco .. I don't know the exact model.
Apr 12, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Turn down the power on the RBR from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Gaming consoles have best performance if directly wired to the RBR.
Please find model# of ISP Modem.
