EnriqueJ
Feb 01, 2021Aspirant
RBR50 poner IP FIJA a los dispositivos conectados.
Hola buenas tardes. Necesito por favor instrucciones para poner IP fija a todos los dispositivos que conecte al Sistema RBR50, incluso al mismo Router. Gracias
- Feb 01, 2021
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
EnriqueJ
Please, I need instructions or explanation to put fixed or static IP, in the router, in the satellite and in the devices that connect to the RBR50.
This is my router.
Thank you
