EnriqueJ
Feb 01, 2021Aspirant
RBR50 poner IP FIJA a los dispositivos conectados.
Hola buenas tardes. Necesito por favor instrucciones para poner IP fija a todos los dispositivos que conecte al Sistema RBR50, incluso al mismo Router. Gracias
- Feb 01, 2021
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
EnriqueJ
Please, I need instructions or explanation to put fixed or static IP, in the router, in the satellite and in the devices that connect to the RBR50.
This is my router.
Thank you
Feb 01, 2021Guru - Experienced User
Refer to page 73 of the user manual for setting "reserved" IP addresses ON the RBR for your devices. You can set a reserved IP address for the RBS as well:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- EnriqueJFeb 01, 2021Aspirant
Thanks for your reply. In the manual it is indicated that the IPs start with 192.x.x.x., however I have them as 10.x.x.x.
Attached several images for you to check.
If I click add, it shows all the devices, and I select 1, it adds them to fixed IP, I imagine.
The images are in Spanish.
- FURRYe38Feb 01, 2021Guru - Experienced User
If you have 10.something, then your RBR is configured for 10.0.1.1 or something like that. This only happens if your RBR detects a up stream router in front of the RBR that uses 192.168.1.1. The RbR changes to 10.something to avoid the conflict.
Do you have another router infront of the RBR?
Yes I have the router from the Vodafone company.
Router CM DOCSIS 3.0 premium Compal CG7486E
