EnriqueJ
Feb 01, 2021Aspirant
RBR50 poner IP FIJA a los dispositivos conectados.
Hola buenas tardes. Necesito por favor instrucciones para poner IP fija a todos los dispositivos que conecte al Sistema RBR50, incluso al mismo Router. Gracias
- Feb 01, 2021
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
EnriqueJ
Yes I have the router from the Vodafone company.
Router CM DOCSIS 3.0 premium Compal CG7486E
Feb 01, 2021Guru - Experienced User
Couple of options,
