rtparies
Jul 17, 2019Guide
RBR50 PORT forwarding issue
Hello i am having issues with port forwarding .
I have a bunch already configured ( see image)
i am trrying to add a new forward using port 22
i get the error
The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type
As you can see from the image i am NOT using that port
Thanks for any help
Hmmm. A puzzle. When the message is scrolled, it lists a whole bunch of stuff to examine.
Do you have Remote Management turned on?
Any Port Triggers?
Any Services forwarded?
Having "literally nothing" set up on this page, I set up forwarding on Port 22, and it worked just fine. Maybe someone with more experience has a suggestion for what to look at.
- rtpariesGuide
