Konlet
Jul 27, 2020Aspirant
RBR50 Ports won't open
Hello! I'm attempting to forward some ports for the occasional hosting of nodejs/game servers. I have assigned my local PC the internal IP address of 10.0.0.150 and have forwarded ports to that same...
- Jul 27, 2020
Thanks for the information. If this is the product:
https://www.ui.com/ufiber/ufiber-nano-g/
Then, the solution is to place the Nano-g into "bridge" mode and remove the airCube, so the Orbi will be the sole WiFi network.
Jul 27, 2020Guru - Experienced User
- KonletJul 27, 2020AspirantThe ISP's modem appears to be (I'm unable to remove it and check with ease) a Ubiquiti UFiber Nano-G attached to a Ubiquiti airCube. Hopefully that helps, if the models are absolutely necessary I can remove them, but this would take a while.
- CrimpOnJul 27, 2020Guru - Experienced User
- KonletJul 28, 2020Aspirant
Had to call my ISP to enable bridge mode, now I'm able to successfully port forward! Thanks ^^
