Konlet
Jul 27, 2020Aspirant
RBR50 Ports won't open
Hello! I'm attempting to forward some ports for the occasional hosting of nodejs/game servers. I have assigned my local PC the internal IP address of 10.0.0.150 and have forwarded ports to that same...
- Jul 27, 2020
Thanks for the information. If this is the product:
https://www.ui.com/ufiber/ufiber-nano-g/
Then, the solution is to place the Nano-g into "bridge" mode and remove the airCube, so the Orbi will be the sole WiFi network.
CrimpOn
Jul 27, 2020Guru - Experienced User
FURRYe38is asking for the specific model of ISP device the Orbi is connected to because this sounds very much like a "Double NAT" situation: https://kb.netgear.com/30186/What-is-Double-NAT
If this is the case, then the ISP device is blocking connections from reaching the Orbi.
