Konlet
Jul 27, 2020Aspirant
RBR50 Ports won't open
Hello! I'm attempting to forward some ports for the occasional hosting of nodejs/game servers. I have assigned my local PC the internal IP address of 10.0.0.150 and have forwarded ports to that same...
- Jul 27, 2020
Thanks for the information. If this is the product:
https://www.ui.com/ufiber/ufiber-nano-g/
Then, the solution is to place the Nano-g into "bridge" mode and remove the airCube, so the Orbi will be the sole WiFi network.
Konlet
The ISP's modem appears to be (I'm unable to remove it and check with ease) a Ubiquiti UFiber Nano-G attached to a Ubiquiti airCube. Hopefully that helps, if the models are absolutely necessary I can remove them, but this would take a while.
CrimpOn
Jul 27, 2020Guru - Experienced User
