Nasshop
May 03, 2021Tutor
RBR50 Position
I live in a long narrow single storey house that has solid walls. Siting the Orbi router and satellites is tricky to get them to connect and provide adequate coverage. The loft is continuous and open...
May 03, 2021Guru - Experienced User
Yes each unit broadcasts in 360 degree pattern. Something you'll need try and see if your idea works or not.
Nasshop
May 05, 2021Tutor
The trial positioning of the Orbis has worked well. I have a stronger, wider signal throughout the house now and better coverage outside too. I just need to get on with doing the work to make the installation more permanent and neater. I'll come back if I hit any problems!
Thanks for the help so far Furry.
- FURRYe38May 05, 2021Guru - Experienced User
Glad you got it working better. Good to spread the wifi signal out farther for sure. Please mark your thread and solved so others will know.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. :smileywink:
Nasshop wrote:The trial positioning of the Orbis has worked well. I have a stronger, wider signal throughout the house now and better coverage outside too. I just need to get on with doing the work to make the installation more permanent and neater. I'll come back if I hit any problems!
- NasshopMay 05, 2021Tutor
Do you mean WiFi range or siting of the Orbis?
- NasshopMay 06, 2021Tutor
Oh, ok. The router is in the centre of the roof space with the satellites at each end, about 25ft from the router.
