Nasshop
May 03, 2021Tutor
RBR50 Position
I live in a long narrow single storey house that has solid walls. Siting the Orbi router and satellites is tricky to get them to connect and provide adequate coverage. The loft is continuous and open...
Nasshop
May 04, 2021Tutor
The trial positioning of the Orbis has worked well. I have a stronger, wider signal throughout the house now and better coverage outside too. I just need to get on with doing the work to make the installation more permanent and neater. I'll come back if I hit any problems!
Thanks for the help so far Furry.
May 05, 2021Guru - Experienced User
Glad you got it working better. Good to spread the wifi signal out farther for sure. Please mark your thread and solved so others will know.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy. :smileywink:
Nasshop wrote:The trial positioning of the Orbis has worked well. I have a stronger, wider signal throughout the house now and better coverage outside too. I just need to get on with doing the work to make the installation more permanent and neater. I'll come back if I hit any problems!
