Raymond3764
Nov 11, 2024Tutor
RBR50 powerled RED
I hope you can help me. Yesterday I had to reboot my modem (which is in brdge mode). After that, I also did a reboot of my Netgear router. I restarted the modem, when ready, I restarted my ro...
- Nov 12, 2024
If your still wanting to use a 50 series system, might check out places like shopgoodwill, ebay or amazon for any used RBR50s that maybe out there. đ
CrimpOn
Nov 11, 2024Guru - Experienced User
I would swap the power plug with one from a satellite and see if that helps. Otherwise, it seems this router has died.
