Raymond3764
Nov 11, 2024Tutor
RBR50 powerled RED
I hope you can help me. Yesterday I had to reboot my modem (which is in brdge mode). After that, I also did a reboot of my Netgear router. I restarted the modem, when ready, I restarted my ro...
- Nov 12, 2024
If your still wanting to use a 50 series system, might check out places like shopgoodwill, ebay or amazon for any used RBR50s that maybe out there. đ
Nov 11, 2024Guru - Experienced User
Might try a 30-30-30 reset on the RBR and see if this clears this condition.
Raymond3764
Nov 11, 2024Tutor
Thatâs what Idid, but nothing happened unfortunately.
I am afraid it is dead.
Thanks for your answer.
- FURRYe38Nov 12, 2024Guru - Experienced User
You tried.
Good Luck.- Raymond3764Nov 12, 2024TutorYes I dus.
Thanks
I am now configuring the modem from my isp.
Lot of work but I hope I Will be satisfied later.- FURRYe38Nov 12, 2024Guru - Experienced User
