Raymond3764
Nov 11, 2024Tutor
RBR50 powerled RED
I hope you can help me. Yesterday I had to reboot my modem (which is in brdge mode). After that, I also did a reboot of my Netgear router. I restarted the modem, when ready, I restarted my ro...
- Nov 12, 2024
If your still wanting to use a 50 series system, might check out places like shopgoodwill, ebay or amazon for any used RBR50s that maybe out there. 😉
Nov 12, 2024Guru - Experienced User
Raymond3764
Nov 12, 2024Tutor
Do you know if it is possible to buy only a new router and Connect the satallite rbs50?
Will that work?
Will that work?
- Raymond3764Nov 19, 2024TutorThank you all for the reply.
This topic can be closed.
