rbr50user
Sep 10, 2018Follower
RBR50 Problem - Lights blink fast white then amber
Have ORBI running for months. Turned off power to router to move into another room and reconnect. Turned on power and router blinks white then amber continuously. Tried a factory rest and did not ...
Sep 11, 2018Guru - Experienced User
Power OFF the ISP modem and the router together, after 1 minute, power on the modem only and let it sync. Then power ON the router and walk thru the set up wizard if the top led blinks white.
Swap LAN cables or using same cable?
