tommyvan
Mar 19, 2019Follower
RBR50 Problem
Orbi TriBand RBK 50, 3 months old, running V2.2.1.210 in Router Mode with Xfinity Cisco DPC3939 in Bridge Mode.
Working today in IE 11 (Current) reading Gmail.
All internet and local acti...
Chuck_M
Mar 19, 2019Mentor
It sounds like the time it took to come back up was reboot time... Not sure why this happened but I would encourage you to update your firmware to the latest version for stability reasons.
Remember to update the satellites first (they can go directly to version .32)
Then update the router... but you will have to go to the intermediate version before going to the objective version (.32)
Look at the threads on here with details and links to firmware.
Just to be sure all gremlins are out of the system, after upgrade, do a factory reset to clear out any odd settings.
A little bit of a PITA, but I believe you will appreciate the update and associated stability.
