2558-mata
Jul 05, 2020Aspirant
RBR50 probleme mise a jour
bonjour suite a une mise a jour manuel de mon RBR50 je n'ai plus de connexion internet la base clignote blanc et le bouton on/of passe de vert a l'allumage puis clignote quelques instants rouge p...
- Jul 14, 2020
Hello
my update problem is solved
my firmware installed on the RBR50 was corrupt
I found on the forum the procedure to reinstall the original firmware.
"https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client."
it works without problem.
thank you FURRYe38 for your support.
Jul 13, 2020Guru - Experienced User
Please make contact with NG support about this.
2558-mata wrote:Hello
the problem concerns the RBR50 router.
I can no longer access the settings.
there is no more wifi and no connection with the eternet cable despite a factory reset on the RBR and turning off and on the modem and RBR.
2558-mata
Jul 14, 2020Aspirant
Hello
