jcmacdesigns2
Apr 28, 2023Aspirant
RBR50 Problems updating firmware
A friend gave me her Orbi RBR50 Router and RBS50 satellite. They are set up and I get internet. However, I have problems updating the firmware. The current version is V2.1.4.16_1.0.0.11. f I try to ...
CrimpOn
Apr 28, 2023Guru - Experienced User
You have been caught by a "gotcha" from 2019. The original Orbi firmware was predicted to never exceed a certain size and the update function would check new firmware to ensure that it did not exceed that size. Alas, when Netgear added Armor and Parental Controls the resulting firmware was too large.
A special version of firmware, v2.2.1.212 was released in 2019 to allow for larger firmware images:
https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
That firmware needs to be downloaded (for router and satellite) and manually installed on the router and satellite. (I prefer to connect directly to the satellite web page to update the satellite - use the IP address of the satellite and the same credentials as the router - "admin" + password).
After v2.2.1.212 has been installed, then you can manually update to any version after that.
jcmacdesigns2
Thanks for the quick response. When I tried to manually upload the v2.2.1.212 img file I got the same error message "The firmware file is incorrect. Please get the firmware file again and make sure it is the correct firmware for this product". Also, when I try and update the satellite from the IP address, I get the same message. I am not sure what to do. Any suggestions?
- FURRYe38Apr 28, 2023Guru - Experienced User
Try v2.2.1.210
Be sure your updating any RBS first, then the RBR lastly...
- KevinLiTApr 28, 2023NETGEAR Moderator
Hello jcmacdesigns2 ,
Welcome to the NETGEAR Community!
I understand that you are having issues updating the firmware on your RBR/RBS50. Your Orbi Mesh system is on an older firmware which is causing issues when updating to our most recent firmware release version 2.7.5.4. To successfully update your Orbi Mesh system you will have to update the firmware one version at a time.
Navigate to the link below for the firmware download file for your RBR50 (select view previous versions then start one above your current firmware):
https://www.netgear.com/support/product/RBK50#downloadFor step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
Community Team
- jcmacdesigns2Apr 29, 2023Aspirant
Thanks for your response. I have tried to install Version 2.2.1.210, the next version after the one I currently on the router and satellite but I get the same error messages. Any suggestions on what the issue is?
- CrimpOnApr 29, 2023Guru - Experienced User
The most common issues are
- Not extracting the *.img file from the *.zip file.
- Not browsing to the correct file for the router (RBR in the file name) vs. the satellite (RBS in the file name)
- and occasionally the *.zip file does not download correctly. We have become accustomed to computers "just working" that it is a surprise when something so basic fails.
