jcmacdesigns2
Apr 28, 2023Aspirant
RBR50 Problems updating firmware
A friend gave me her Orbi RBR50 Router and RBS50 satellite. They are set up and I get internet. However, I have problems updating the firmware. The current version is V2.1.4.16_1.0.0.11. f I try to ...
jcmacdesigns2
Thanks for the quick response. When I tried to manually upload the v2.2.1.212 img file I got the same error message "The firmware file is incorrect. Please get the firmware file again and make sure it is the correct firmware for this product". Also, when I try and update the satellite from the IP address, I get the same message. I am not sure what to do. Any suggestions?
Apr 28, 2023Guru - Experienced User
Try v2.2.1.210
Be sure your updating any RBS first, then the RBR lastly...
