Breakaway9
Mar 28, 2021Guide
RBR50 Problems
After experiencing significant problems with my RBR10 in one location, and my RBR50 285 miles away and posting in this community on 3/22/2021 with no solutions provided by Netgear or the community, I...
Wire1852
Mar 28, 2021Apprentice
To Breakaway9
Which firmware version did she walk you back to?
Breakaway9
Mar 28, 2021Guide
V2.5.2.4 and now I can't use the Orbi app unless I disconnect from my WiFi and use Anywhere Access. I had to figure that one out on my own. She told me simply that I would no longer be able to use the app until they fix this problem.
- Wire1852Mar 28, 2021Apprentice
So Netgear had you install an old firmware version released in September of last year and none of the 5 versions that has been release over the last 6 months.
That stongly implies that Netgear staff considers v2.5.2.4 to be it's latest & stable Orbi firmware version, Also notice it was 6 months between the release of v2.5.2.4 & previous version v2.5.1.16 but in 6 months since v2.5.2.4 was released there has been 5 new versions released.
Netgear has a quality control issue in it's Orbi software development & it's getting worse.
Breakaway9 wrote:V2.5.2.4 and now I can't use the Orbi app unless I disconnect from my WiFi and use Anywhere Access. I had to figure that one out on my own. She told me simply that I would no longer be able to use the app until they fix this problem.
