presidentskroob
Mar 31, 2020Tutor
RBR50 providing poor (<5mbps) download speeds to entire network (both wired and wireless)
I've had an Orbi RBR50 for about two years. For some reason, it has started to provide incredibly slow speeds to the devices on the network. My service package is for 200mbps download, and if I plug ...
presidentskroob
Apr 01, 2020Tutor
I do not have Circle or Armor on. Factory reset maybe I screwed up, because I tried it last night and used the pin and stuff, waited until the power light was flashing amber after holding the pin in for about five seconds, but all of my settings were still there when I rebooted. Perhaps I need to try harder.
The previous issue with slowness went away with a factory reset. The disconnects, generally several times a day, have persisted, and I just live with them.
I'll try harder on the factory reset and see if it helps.
Apr 01, 2020Guru - Experienced User
Press the reset button for 15 seconds then release. v2.5.18 is not the problem. Working well for me and others.
- Retired_MemberApr 01, 2020
FURRYe38 wrote:v2.5.18 is not the problem.
Not true....the number of people who have found relief by reverting back proves you wrong
