presidentskroob
Mar 31, 2020Tutor
RBR50 providing poor (<5mbps) download speeds to entire network (both wired and wireless)
I've had an Orbi RBR50 for about two years. For some reason, it has started to provide incredibly slow speeds to the devices on the network. My service package is for 200mbps download, and if I plug ...
Retired_Member
Apr 01, 2020
presidentskroob wrote:I've had an Orbi RBR50 for about two years. For some reason, it has started to provide incredibly slow speeds to the devices on the network. My service package is for 200mbps download, and if I plug directly into the modem I get that 200mbps download. However, running a speed test from the router itself yields a 5mbps download speed and running tests from devices on the network generally gives around 3.
I haven't changed anything in the configuration in a while. I shut off both wireless networks and ran it just wired devices, and then unplugged all the wired devices except my PC, and still the same.
Firmware version is V2.5.1.8. There are generally around 20 devices total on the network, though as I mentioned even with just a single device I'm having the same experience.
here's your problem: Firmware version is V2.5.1.8.
