RJSinMO
Dec 19, 2023Guide
RBR50 pulse white, then flash green and red and reboots endless
I have an RBR50 that about a week ago hung up. I powered off and on and now it just pulses white and then will do a quick flash of green and flash of red (on top ring). I factory reset it, and even...
RJSinMO
Dec 20, 2023Guide
Well, it seems like one of the satellite's was hanging it up. Once I turned off that satellite, the main router fired right up.
- FURRYe38Dec 21, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the size of your home? Sq Ft?What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
