RJSinMO
Dec 19, 2023Guide
RBR50 pulse white, then flash green and red and reboots endless
I have an RBR50 that about a week ago hung up. I powered off and on and now it just pulses white and then will do a quick flash of green and flash of red (on top ring). I factory reset it, and even...
RJSinMO
Dec 20, 2023Guide
Well, it seems like one of the satellite's was hanging it up. Once I turned off that satellite, the main router fired right up.
Dec 21, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
