DY65's avatar
DY65
RBR50 Questions
I have had the RBR50 for a couple years and have had no problems.
Recently I have been losing wifi many times per day. Firmware is V2.7.4.24. Internet provider is Spectrum.
I have good internet over ethernet. but wireless devices drop randomly during the day.
I logged on to http://orbilogin.net and noticed my logs were full of DOS attacks. Today Feb 14th there are over 50. Is this my issue? If so how do I solve this?
Thanks
  • CrimpOn's avatar
    CrimpOn
    Those "Denial of Service (DOS) Attacks" are almost certainly not the cause.  Everybody gets those, every day.  I email the Orbi log to myself every time it fills.  In the month of January, there were 1,097 "DOS Attacks" in the log.  So far this January 387.  The high was Aug 2021 with 1,871 in 31 days.
    If these events were going to affect the router, they would affect every device on the network.
    I am using the same RBR50 router with the same firmware, v2.7.4.24 - which has been on the router since May 23 of last year.
    When devices on WiFi "drop", does the connection come back "by itself", or do you do something to the router?
    • DY65's avatar
      DY65
      The modem is a Motorola SB6141.
      No I do not have not do anything, it just comes back. It is intermittent and frustrating. This morning for example I was on my iPad and noticed it slowing down. Slowing down to the point that it stops loading photos or freezes a video while browsing Instagram.
      I ran speedtest and got long ping (several 100ms) and then really low Mbps (3 - 8 Mbps). 30 seconds later it could be 20Mbps or even as high as 118Mbps. This is all from the same location (about 30 feet away from my RBR50 Satellite on the same floor, wooden construction home). See photo. iPad on the left windows computer on the right.
      At the same time I am running speedtest on my desktop that is connected directly to the Motorola SB6141. With that I am getting low ping and download speeds of about 117 Mbps.
      Could it be interference from a neighbor?  2.4GHz is set to auto and 5GHz to 48. It has worked well for a couple of years but lately not so good.
      • CrimpOn's avatar
        CrimpOn
        Yes. This is "just a modem".  The Orbi must remain in "router mode".
  • michaelkenward's avatar
    michaelkenward
    It might help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello DY65,
      Welcome to the NETGEAR Community!
      I understand that you are having multiple disconnects with your RBR50. Have you tried placing your RBR50 in AP mode or your ISP router in bridge mode to resolve this issue?
      Best,
      Kevin
      Community Team
      • DY65's avatar
        DY65
        I wish I understood what AP mode meant, but from what I understand does that apply to me since my router does not broadcast a wifi signal?
