kodas
May 08, 2020Guide
RBR50 Random Lag Spikes Throughout the day
I dont know if this issue is related to my ISP or if its my Orbi router/satellite. I am connected through ethernet to my orbi router but this issue has been happening for as long as I can remember, a...
May 08, 2020Guru - Experienced User
- kodasMay 08, 2020Guide
Im not connected wireless Im connected through ethernet to my router, and I disabled Daisy Chain but I dont know how to disable the other things you mentioned like Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
