kodas
May 08, 2020Guide
RBR50 Random Lag Spikes Throughout the day
I dont know if this issue is related to my ISP or if its my Orbi router/satellite. I am connected through ethernet to my orbi router but this issue has been happening for as long as I can remember, a...
May 08, 2020Guru - Experienced User
What modem are you on?
Your firmware is out of date. the firmware the RBR50 is currently on is 2.5.1.16.
Make sure the satellites are updated first before updating the router. You didn't put what version they're on but worth checking.
Also, is it all devices? Devices connected to satellites? wired devices too? or only wireless?
kodas
May 08, 2020Guide
Im using the modem my ISP gave me, Im hardwired with ethernet to my orbi router, I also dont know how to check what firmware version Im on for my satellite, im not finding it anywhere in the routerlogin page for my orbi router
- plemansMay 08, 2020Guru - Experienced User
here's some instructions on how to check and manually update.
