danielj
Jan 27, 2022Aspirant
RBR50 randomly blocking devices and then responding extremely slowly
I've been having ongoing issues with my RBR50 deciding to block devices (without any input from me). They are not new devices but existing devices that have previously connected without issue. T...
Jan 29, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Circle enabled?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
