jimmauro
Sep 13, 2022Aspirant
RBR50 randomly reboots
My RBR50 Router, connected to my AT&T BGW210 (AT&T Fiber), has been randomly rebooting about twice a week. Nothing in the logs. No indication of anything from the BGW210 side. We simply notice tha...
jimmauro
Sep 17, 2022Aspirant
Thanks. I updated both my RBS50 Satellites and the RBR50 router with the latest firmware this morning.
As the reboots have been random, I need to wait at least 2 weeks before I start to feel warm and fuzzy that the issue is resolved.
I will post an update here either way.
Best
Jim
Sep 30, 2022Guru - Experienced User
You might give Voxels 3rd party FW a try as well. If the reboot still happens even with this FW, then there is either a HW problem or a environment problem.
Good luck.
- jimmauroSep 30, 2022Aspirant
Thanks. I may try that. I do not think it's environmental, as they AT&T BGW210 and the RBR50 are plugged into the same
surge protector, and the BGW210 is not restarting.
I just swapped the power supply between one of the satellites and the router. Will see what that does.
If I get another router reboot, I may try the 3rd party firmware - need to think about that, but I do appreciate the note.
Best
Jim
- FURRYe38Sep 30, 2022Guru - Experienced User
đ
