superczar
Oct 17, 2019Apprentice
RBR50, RBS50 and RBS20 - Network being segmented?
I had a RBK50 (RBR50 and RBS50 ) that had been running fine for 2 years with a couple of firmware upgrades and minor woes in between. Yesterday I added a RBS 20 as a second satellite which is wh...
CrimpOn
Oct 17, 2019Guru - Experienced User
A good explanation, but the typos left me confused. (too many RBS20's, not enough RBS50's).
Could you please make a simple drawing showing exactly how the RBS50 and RBS20 connect to the RBR50?
Are they wired directly to RBR50 LAN ports, or do either of them connect through the switch?
superczar
Hopefully this makes more sense (See attached drawing).
Testing just now after a full reset - For example, PC 1 can ping RBS20 but not RBS50
However if I telnet into any of RBS20, RBS50 or RBR50 , they can all ping each other just fine
- CrimpOnOct 17, 2019Guru - Experienced User
Oh, my. You can telnet into the RBS50, but cannot ping the RBS50?
Can you open the RBS50 web page?
- superczarOct 17, 2019Apprentice
Just got done with my troubleshooting and Actually it appears to be a lot more complicated than that
I think this is most definitely a seriously bad bug I have identified.
The subject line is misleading so I will have to open a separate thread for this I guess
- FURRYe38Oct 17, 2019Guru - Experienced User
Is that a NG GS-108e? Please reconfirm the model of this switch.
Are the RBS wired or wireless connected to the RBR?
Added more details here
