superczar
Oct 17, 2019Apprentice
RBR50, RBS50 and RBS20 - Network being segmented?
I had a RBK50 (RBR50 and RBS50 ) that had been running fine for 2 years with a couple of firmware upgrades and minor woes in between. Yesterday I added a RBS 20 as a second satellite which is wh...
superczar
Hopefully this makes more sense (See attached drawing).
Testing just now after a full reset - For example, PC 1 can ping RBS20 but not RBS50
However if I telnet into any of RBS20, RBS50 or RBR50 , they can all ping each other just fine
CrimpOn
Oct 17, 2019Guru - Experienced User
Oh, my. You can telnet into the RBS50, but cannot ping the RBS50?
Can you open the RBS50 web page?
- superczarOct 17, 2019Apprentice
Just got done with my troubleshooting and Actually it appears to be a lot more complicated than that
I think this is most definitely a seriously bad bug I have identified.
The subject line is misleading so I will have to open a separate thread for this I guess
- FURRYe38Oct 17, 2019Guru - Experienced User
Is that a NG GS-108e? Please reconfirm the model of this switch.
Are the RBS wired or wireless connected to the RBR?
