Badger21's avatar
Jan 01, 2021
RBR50, RBS50 won't find 2.7.1.60 firmware update
I got the email from Netgear today informing me I needed to update the firmware to the latest version for security reasons, neither the app or the web interface will find the latest update online. It just says no new firmware available even though it's on 2.5.2.4. I've tried restartting the router but it still won't find the new update.
I prefer not to attempt a manual update as I'm not a technical user.
  • Manual update to ver 2.7.1.60 is the only option at this time. Netgear has not placed newer versions on their update servers.
    There are lots of threads here discussing the pros/cons for updating (or not) manually.  Please read and then decide if you are up to it.
    • Badger21's avatar
      Badger21
      Tutor
      They really should mention that, instead of just including a link with instructions of how to update through the app.
      • alokeprasad's avatar
        alokeprasad
        Mentor
        No arguments there.
        Better still, they should make the version they want users to use, after quality-checking it for bugs and smooth installation, availabe for upgrade using the normal update proccess: iOS and Android app and web interface.
  • FURRYe38's avatar
    If your in the USA region, then v2.7 can be used:
    You can manaually download v60 files from NGs support site. Apply v60 to the RBS first then RBR lastly. You'll see v102 available then on the RBRs web page.
    https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2027821/highlight/true#M109584
    If your not in the USA, then most current version for all other regions is v40:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-Version-2-6-1-40/m-p/1997895/highlight/true#M105941
    Up to you if you wanna update. Good Luck.
  • I went ahead with the manual update.
    Satalite first and then router (connected through a switch port to the router), then after I gave it a awhile to reboot, launching the iOS app it prompted me to update the satalite firmware again. So updated the satalite firmware again (this time through the app) and I'm now on version 2.7.2.102 for both the router and satailite.
    • FURRYe38's avatar
      Glad the update went well for you. I recommend making a backup configuration to file for safe keeping. Helps safe time if a reset is needed.
      Enjoy.
