JamesBr
Jul 25, 2020Aspirant
RBR50, RBS50,Outdoor Orbi
Greetings all! After an hour + wait for tech support chat with no reply, and no answers I turn to the community for hopefully some user answers. I installed the Orbi AC3000(main router and 2 satell...
Jul 25, 2020Guru - Experienced User
I
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- JamesBrJul 25, 2020Aspirant
Greetings and thank you for your reply. here are some answers to your Q
1. Firmware is V2.5.1.8
2. Comtrend B673...service provided by Fairpoint which has been bought up by west
coast company Consolidated. I'm in north VT
3. Older farm house with additions, not sure of SQFT. Have played with satallite locations to get green light when setting up. The RBR50 is at front of house in center on ground floor where where phone line comes in and DSL router has to be. The two RBS50 satallites are upstairs 1 floor in each wing/addition and are pretty stable though one goes orange every so often...Varous walls thickness etc.
Ive just bought and added an outdoor unit to
see if I can extend coverage to barn across driveway...so far just orange, but playing with the location still
4. Live in country with the nearest neighbor blocks away. Where do I check to see which settings you mention Auto,....etc
5. All the of your next Q's are beyond my knowledge/ experience at this point. I'm glad to follow steps to those settings if you can provide step by steps.
thanks!
- FURRYe38Jul 25, 2020Guru - Experienced User
Whawt mode is your modem working in? Bridged or router mode? If your modem has a built in router already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopFor the suggestions meantioned already, use a PC or laptop and a web broswer to log into the RBRs web page at 192.168.1.1 or orbilogin.net
- FURRYe38Jul 26, 2020Guru - Experienced User
Be sure that your ISP modem is fully bridged. Have the ISP help with you with this.
After getting the ISP modem bridged and wifi fully disabled. Run the Orbi system for a bit to see how it goes. If you encounter more problems, then I would uddate FW to v16. I'm on v16 now and have not seen any wifi problems. Been most stable version of FW to date IMO. Factory reset and setup from scratch would be recommended after you udpate FW.
JamesBr wrote:Greetings and thank you for your reply. here are some answers to your Q
thanks!
- JamesBrJul 27, 2020Aspirant
Greetings all and good Moday too.
Wanted to give progress report and ask another q
After many failed attempts I was finally able to log onto the OrbiLogon page after password reset. My first goal was to up date the firmware, which went ok as the Main Router and the two satillites now report version V2.5.1.16
The RBS50Y Outdoor has V2.3.5.32 and said no update available .
Results are interesting and a bit frustrating
The RBS50YBackhaul status was "poor" online and orange in phone app, and was also show in network map coming off one of the sattilites.
After the firmware updates it changed to "Good" backhaul status online under the attached devices window to match the others "good", and on the phone app had gone green and appeared for the first time in network map off the RBR50 main router and not off the closest sattalite. But after I rebooted the main unit RBR50...the out door satallite has returned to "poor" and Orange again. A short lived victory! So now what? A re-sync?
One new question regarding that unit is I noticed when online the default setting is SYNC off. What does that mean? I did the setup as directions reccomended using the buttons on back. I did searches regarding what that setting means but nothing in the user manual or online that helps explain what that setting is for?
I'm still waiting to hear back from the isp regarding the double Natt and bridge mode.
Is there anyone who has knowledge of the Comtrend ADSL2+ Router, Model #AR-5319
It says in the 2 pages availible online that it has a WIFI on/off button, on the front of the unit but pushing it doesn't seem to do anything. Perhaps there is a sequence? I've tested with my cell phone wifi to logon directly and then push the button, but it never disconnect me. Perhaps there ii a way of Logon via the HTTP page but I have not had any luck
finding a address to use...Or does the ISP only allow their access perhaps?
I'll be rereading the reply to see what else was reccommnded now that I can access the settings pages
thanks in advance
