hollang
Jan 13, 2019Tutor
RBR50 ReadySHARE USB Printer
I have Orbi RBR50 with two satellites. From a wifi perspective it works great, but for the life of me I can't get a HP CP3252 Color Laser Jet printer to work over the USB port on the back of the sate...
- Jan 13, 2019
Thanks again. In the interim, I uninstalled the driver and the ReadyShare software and reinstalled them and now it's working correctly. Guess some kind of conflict occurred. So, I thik I'll just stick with the USB connection as I don't use this color LJ very often.
Jan 13, 2019Guru - Experienced User
I would review this to see if anything helps here:
https://www.netgear.com/support/product/ReadySHARE_USB_Printer.aspx
Also your printer has a LAN port on the back. I might work better to connect the printer via LAN port to the Orbi and then install drivers on your PCs and direct the drivers to the IP address the printer gets from the router.
hollang
Jan 13, 2019Tutor
Thanks. I’d reviewed that information, downloaded & installed the app with no complaints but it’s not operating as described. I get the language prompt screen but nothing follows it. I would use an Ethernet port but I need them all. Maybe I can connect up an energy switch to get more ports. …? Thanks, though for your inputs.
- FURRYe38Jan 13, 2019Guru - Experienced User
Possible something wrong with the app. Maybe a forum moderator can help.
Yes you can add a external Gb network switch to the back fo the Orbi router for more ports. I have a 24port and several smaller switches behind my router. Non managed, non smart and non green eithernet is preferred. NG GS308 or D-Link DGS 108/105 or HP 1400 series works great.
- hollangJan 13, 2019TutorI assume I can use something slower than a Gb switch like a 100 Mb or even older 10 Mb device. Will try that next. Just have to find power adapters for my old switchs
Though it may work, 100 and 10Mb switches will bottle neck speeds on the LAN side. I highly recommend getting into the same 1000mb rated switch as the router. If you do have devices that are rated for the 10Mb or 100Mb rates, let the switch handle that. Keep same rates between router and switch for best performance and operation. 10mb switch are old and not readily available and they are not switches, they are hubs which all data and traffic is seen by any devices connected to the hub. Some older 100Mb were both Hubs and switches. 100Mb Switch are also not readily available while 1000mb switches are. Switches now days route traffic to the connected device on the LAN port which the device was routed to or from and not see by all other devices connected to the switch.
There inexpensive and available from places like Amazon. I bought several from there.
