Balmhood
Jun 17, 2020Tutor
RBR50 rebooting at least once a day
Hi all, I have been searching on the forum to try and find a solution to my Orbi router rebooting to no avail but for an RMA ☹. This seems to be happening at least once a day and is confirmed by th...
- Jul 14, 2020
Update:
I have received a new unit under warranty from Netgear and I can say the problem seems to now be solved. Unit has been running for 3 days straight without a single reboot. I guess it was a faulty unit.
One of the troubleshooting steps they gave me if that can help someone in the future was to switch the power adapter between satellite and router to see if the issue persisted. In my case, this didn't solve it but it may help others.
thanks to FURRYe38 who tried to help but this was obviously not a software issuse.
Problems-123
Jun 17, 2020Tutor
Hello,
I'm sorry, but I have no answers: Only sympathy.
I have an RBR50 base unit that's exhibiting the same problem. It has the most recent firmware V2.5.1.16. It's connected to a Quantum Gateway G1100 modem. Until last night, I was using the modem in AP mode and changed all the same settings you tried changing.
When I first got the Orbi I had an RBR50 with two RBS50 routers. The base (RBR50) was in the basement of our home, and I put one RBS50 on each of the two stories of the home. After being told on this forum that the satellites were too close together and causing the problem, I have stopped using both satellites. Now the benefit of the mesh network and speed throughout the home is lost.
Since I have owned the router, once a day or so the router "disappears". All devices connected to it by Wi-Fi or hardwired lose connectivity and the RBR50 begins flashing slow white. This is the same behavior that occurs when intentionally restarting/rebooting the RBR50. It takes two to five minutes, and then the RBR 50 acts fine for another 18 to 28 hours before randomly rebooting again.
Before March, this was fine. Rarely was I doing much with the Internet when this happened. Occasionally it would interrupt a movie or TV show, but that was rare. It would happen when I was at work or overnight. Now, I am home ALL THE TIME and using the internet for work ten hours a day. It's no longer O.K.
Last night I spent over an hour on the phone with Netgear support. We performed a reset of the RBR50 and afterwards, the phone disconnected, and I was stranded without internet. So, I called Netgear back and after another hour on the phone had internet but was back to all factory default settings and operating as a router rather than an access point.
Any firmware update seems to make the network stable for 3 to 5 days (maybe it will again this time). After that time, the daily, random rebooting starts again. I have been through this with their service and tech support people here (in the community), by chat, or by telephone a half dozen times, and no solution has been permanent.
It's conceivable that a billion-dollar computer products company would create a product that isn't compatible with a very popular modem used by the most popular home fiber provider, but that seems short sighted and something fixable during one of the firmware updates issued by the company. It's also conceivable that this large company would create incompatible bases and satellites and sell them together in the same box. Both of those, however, seem unlikely. I think the more likely scenario is that there's a hardware issue plaguing the RBR50 -- at least a small number of these devices.
I apologize for not having a solution, but I hope that by sharing this it helps the company or community find an answer or begin to replace the units.
