Balmhood
Jun 17, 2020Tutor
RBR50 rebooting at least once a day
Hi all, I have been searching on the forum to try and find a solution to my Orbi router rebooting to no avail but for an RMA ☹. This seems to be happening at least once a day and is confirmed by th...
- Jul 14, 2020
Update:
I have received a new unit under warranty from Netgear and I can say the problem seems to now be solved. Unit has been running for 3 days straight without a single reboot. I guess it was a faulty unit.
One of the troubleshooting steps they gave me if that can help someone in the future was to switch the power adapter between satellite and router to see if the issue persisted. In my case, this didn't solve it but it may help others.
thanks to FURRYe38 who tried to help but this was obviously not a software issuse.
time2ski4us
Jun 27, 2020Aspirant
I have the exact same problem. Multiple reboots in a day. The log gets cleared each time so I can't see what may have cause it. Now that we all work at home this is killing us during work hours. I'm considering going back to the Apple Airport that was extremely reliable.
- FURRYe38Jun 27, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
time2ski4us wrote:I have the exact same problem. Multiple reboots in a day. The log gets cleared each time so I can't see what may have cause it. Now that we all work at home this is killing us during work hours. I'm considering going back to the Apple Airport that was extremely reliable.
