wegunterjr
Dec 10, 2019Guide
rbr50 rebooting FW 2.3.5.0
Not sure what is going on, but cannot keep connected for longer than about 30 minutes and then the orbi reboots or something. I have performed a factory reset. It is connected directly to my fiber ...
Dec 10, 2019Guru - Experienced User
What Firmware is currently loaded? Please confirm version...
wegunterjr
Dec 10, 2019Guide
I put the version in the title of the issue.
I am not sure about the
I have tried 1,6,11.
Distance between satellites is less than 30', but not turned on right now.
I am just using the router for now, and no satellites.
| Hardware Version | RBR50 |
| Firmware Version | V2.3.5.30 |
| GUI Language Version | V1.0.0.360 |
| Operation Mode | Router |
What would cause the reboot?
Walter
