wegunterjr
Dec 10, 2019Guide
rbr50 rebooting FW 2.3.5.0
Not sure what is going on, but cannot keep connected for longer than about 30 minutes and then the orbi reboots or something. I have performed a factory reset. It is connected directly to my fiber ...
wegunterjr
Dec 10, 2019Guide
It has worked awesome for over a year, but just moved into a new home (both have fiber).
| Lease Obtained | 0 Days, 23 Hours, 0 Minutes |
| Lease Expires | 0 Days, 21 Hours, 22 Minutes |
CrimpOn
Dec 10, 2019Guru - Experienced User
Thanks for the quick response. Well... that shoots my theory all to hell. A 1 day DHCP lease is pretty much "standard".
Can you describe more about what happens and when it happens?
- wegunterjrDec 10, 2019Guide
it is typically about every 30 minutes, the WiFi just drops.
then takes a minute or two to reboot.
The SSID disappears...strange...
- FURRYe38Dec 10, 2019Guru - Experienced User
What devices do you have connected to the system? Wired and wireless?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any closer can be problematic...when you go to turn the RBS back on.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
wegunterjr wrote:it is typically about every 30 minutes, the WiFi just drops.
none of this works. what is wrong with this firmware?
