gregsorbi
Mar 24, 2019Aspirant
RBR50 rebooting hourly
RBR50 w/ 1 RBS50 Satellite ~ 30 feet (synchs blue)
Firmware 2.3.1.44
Spectrum w/ Arris TM1602 modem
WPA2-PRK [AES]
House 2,700 sq ft
Edge of Neighbor's house ~110 feet can see their wifi very low signal
Router is resetting frequently. Today has been every hour..
2.4 is set to channel 11.
Beamforming is on.
MIMO is on
Daisy-Chain is on
When router goes into factory reset/update mode if I plug internet directly into computer internet is available, so doesnt seem like the cable is the issue.
Reset it to factor default yesterday
Any suggestions?
- ekhalilMaster
How do you see that the Router is rebooting? Do you see in the Logs (in the web GUI under >> ADVANCED >> Administration >> Logs) that the router is initialized?
- gregsorbiAspirant
A few of the times I've been sitting there when it starts pulsating white.
Yes, log looks like this, rarely see entries spanning longer than an hour.
[DoS Attack: ACK Scan] from source: 17.33.9.65, port 443, Sunday, March 24, 2019 16:38:00
[admin login] from source 192.168.1.9, Sunday, March 24, 2019 16:37:55
[DHCP IP: 192.168.1.7] to MAC address f0:98:9d:4b:df:85, Sunday, March 24, 2019 16:37:42
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:37:25
[DHCP IP: 192.168.1.5] to MAC address 7c:1c:4e:57:96:ea, Sunday, March 24, 2019 16:36:25
[DHCP IP: 192.168.1.4] to MAC address 08:02:8e:90:9b:c0, Sunday, March 24, 2019 16:36:15
[DHCP IP: 192.168.1.3] to MAC address 68:9a:87:bb:75:b6, Sunday, March 24, 2019 16:35:55
[DHCP IP: 192.168.1.2] to MAC address 68:9a:87:c4:a4:97, Sunday, March 24, 2019 16:35:53
[Time synchronized with NTP server] Sunday, March 24, 2019 16:35:35
[Initialized, firmware version: V2.3.1.44] Sunday, March 24, 2019 16:35:19- gregsorbiAspirant
and again and this time it lost it's time zone. It's should be 17:51
[DHCP IP: 192.168.1.7] to MAC address f0:98:9d:4b:df:85, Sunday, March 24, 2019 16:52:45
[admin login] from source 192.168.1.9, Sunday, March 24, 2019 16:52:44
[admin login failure] from source 192.168.1.9, Sunday, March 24, 2019 16:52:41
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:52:22
[DHCP IP: 192.168.1.5] to MAC address 08:02:8e:90:9b:c0, Sunday, March 24, 2019 16:52:07
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:52:02
[DHCP IP: 192.168.1.4] to MAC address 7c:1c:4e:57:96:ea, Sunday, March 24, 2019 16:51:54
[DHCP IP: 192.168.1.6] to MAC address f8:95:ea:12:48:48, Sunday, March 24, 2019 16:51:52
[DHCP IP: 192.168.1.10] to MAC address 48:bf:6b:3f:b4:77, Sunday, March 24, 2019 16:51:50
[DHCP IP: 192.168.1.6] to MAC address f8:95:ea:12:48:48, Sunday, March 24, 2019 16:51:50
[DHCP IP: 192.168.1.3] to MAC address 68:9a:87:bb:75:b6, Sunday, March 24, 2019 16:51:47
[DHCP IP: 192.168.1.2] to MAC address 68:9a:87:c4:a4:97, Sunday, March 24, 2019 16:51:47
[Time synchronized with NTP server] Sunday, March 24, 2019 16:51:26
[Initialized, firmware version: V2.3.1.44] Sunday, March 24, 2019 16:51:11
Since you only have 1 satellite, I would disable Daisy Chain.
Did you reset both base and satellite and setup from scratch?
