brandon19
Feb 21, 2019Aspirant
RBR50 rebooting several times during the day
I have a pc hard wired to the RBS50 Satellite and lose the connections several times during the day. I also had a NAS attached but moved it to the RBR50 Router. I have changed both wireless channels ...
Chuck_M
Feb 21, 2019Mentor
Can you estimate how many times a day it is going off line?
Always at about the same time?
How many hours between each drop?
Chuck_M
Feb 21, 2019Mentor
Your modem is a router and a telephone gateway
https://arris.secure.force.com/consumers/ConsumerProductDetail?p=a0ha000000TnNmSAAV&c=Touchstone
You need to either bridge that modem or use Orbi In AP mode.
I presume you use telephones through this modem?
- brandon19Feb 21, 2019Aspirant
Yes the modem is in bridge with the Orbi in router. I setup a static route to the satellite and haven't had an issue for the rest of the day. I will post again tomorrow if it continues.
- FURRYe38Feb 22, 2019Guru - Experienced User
How was this configured? Just curious.
- brandon19Feb 22, 2019Aspirant
If you login to the Arris modem under LAN Settings you change the NAT mode to: Bridged (Data will pass through the device directly without any routing)
The Wireless setting on this Arris modem has been disabled due to me not paying Spectrum for the added wireless service.
