timorbi
Jul 22, 2020Aspirant
RBR50 regularly needs power cycling
I'm getting sick and tired of this kit. Every now again, sometimes after weeks sometimes after days, I lose internet connectivity. This is usually resolved by switching off the satellite, switching...
Jul 22, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- timorbiJul 24, 2020Aspirant
Thank you Furrye38 for taking an interest in this, but the problems I am experiencing are to do with access to the internet from my local network, not access to the router and satellite by wifi, which has always been fine.
The problems have persisted across various versions of firmware, but if part of the solution is to do a hardware reset and setup from scratch each time the firmware is updated, then that itself would be a very severe problem.
- FURRYe38Jul 24, 2020Guru - Experienced User
Please provide feedback to the questions presented so we can get an idea of your situation and configuration. This helps us help you with some suggestions and ideas on areas that should be vetted and narrowed down to see if the problems is with Orbi or not. IF you think the problem is sever then you may need to contact NG support directly if we can't help you here in the forums.
