nmoncivais
May 07, 2020Follower
Rbr50 replacement
So I received a replacement router due to my router randomly rebooting itself daily. What’s the best/easiest way to set up the new router-through the app as a “new set up”?
michaelkenward
May 08, 2020Guru - Experienced User
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Find the setup guide and follow that.
