Sarabpaints
Sep 26, 2022Follower
Rbr50 reset Orbi and now it won’t connect to the Internet
I have an Orbi90 rbr50 and it won’t connect to the Internet. Every time I restarted it it would go back to the pink light. So I reset it and now it is a white light but it is still not working. How do...
Sep 26, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Jeezy
Sep 29, 2022Tutor
OP did you manage to sort this? I am having the same issues.. wirelessly I am getting slow speeds. I tell you what Netgear Orbi is a pain in the ass. I regret getting this. You would expect for such a expensive equipment you wouldn’t have much headache with it
- FURRYe38Sep 29, 2022Guru - Experienced User
The user hasn't been back since they posted nor responded to my suggestions.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
